JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Airspeed Sensor
Old 05-31-2003 | 03:25 PM
Default Airspeed Sensor
I have a airspeed sensor from Jetcat, I would like to try to use it, the only thing I would like to do with it is get the MAX speed. It plugged it in last year, but I found a setting or message on the GSU that I didn't understand so I didn't take a chance on it. Does anyone have a set of instruction for one, that has detail info of the setting it will give my on the GSU, or any personnel info you can give me. I have a P80 with the new ECU v4.0. Thank you Kelly
Old 05-31-2003 | 05:47 PM
mr_matt's Avatar
My Feedback: (10)
Default Hi Kelly
On page 61 of the manual, the MAX LimitAirSpd parameter is explained.
This limit is in effect no matter what other airspeed functions (such as "hold speed", "cruise control", etc.) that you have enabled. You can even run in "single channel" mode and still have this function available.
You can also run the pump-less smoke system with aux 2 and have a max limit airspeed as well.
The manual is available at
http://www.jetcatusa.com/PDFFiles/In...onManualV4.pdf
Good luck and feel free to ask if you have any other questions,
