Propane start question
I now have 14 flights on my elan with a P-80 se. The first flight of each day I get the blue propane flame at the tailpipe before the pump kicks in for the Kero. I have tried several ways to avoid this. I use just a short squirt of propane into the onboard tank, and I have cut the % of gas down to 60% from 80%. I still get the propane blue flame though.
It is becoming annoying as I give a quick burst of Co2 each time this happens.
The temps here in Tucson when I fly are in the 90's approaching 100 F. This morning it was in the 80's, and it still happened.
Has anyone else had this problem and if so how did you solve it?
Stan
Stan
ORIGINAL: KC36330
are you using propane or powermax?
I am using Powermax, sorry forgot to mention that. The answer I have received from some local guys is learn to live with it. Other people I have talked to say it never happens to them using the same setup as me. Very frustrating.
Stan
it's normal to get a short blue flame with gas start, but it shouldn't be more then a few inches out the tail cone (which shouldn't be a problem). if you can get a reliable start every time dial the gas flow down a bit more.
ORIGINAL: KC36330
Thanks for your advice.
Stan
gas flow percentages are widely effected by the installation.......full bypass/open/half bypass/etc........ I've ran anywhere from 20% to 80% on differing setups. now i use full offboard and fully control the gas flow myself.
My Feedback: (40)
ORIGINAL: KC36330
Craig
i use full offboard 100% propane (green bottle) with the ECU not having the ability to control anything (no solenoid used), but just for a test i took a fully bypassed installation (Tam F-18) that was setup for onboard PowerMax and after draining the onboard tank i simply hooked an offboard propane to the fill line, opened the regulator fully and initiated a start, she fired right up with no adjustments needed. while I'm sure there will be a few situations that require a small change or two I'd say for the most part you'll get a perfect start with no modifications needed.
My Feedback: (40)
ORIGINAL: KC36330
Craig
