P80 problem
Hi Guys,
I have a P80 and there is a problem on this turbine.
When I put the throttle on 100% the RPM dos not go over than 100,000 RPM ,the maximum pump voltage in full throttle is 1.75 ,I think I must change this item (max pump V) but in GSU I can not change it .
Is there any body can advise me?
Ali
Ali
Connect the GSU and start the turbine.
Throttle up to full power and while at full power press and hold the "Manual" button. You will need to hold full throttle and the Manual button for 30 seconds.
That should allow the ECU PID loops to reset and power up to max RPM and restore the max pump voltage.
if that doesn't work, you can try a soft reset:
press and hold the 'Select Menu' button on GSU, continue to hold as receiver is powered on.
continue holding past Release to Learn RC
continue holding past Release to calibrate temp
the next menu is release to reset
release when you see this, you'll get a press key to reset, press 'Manual' key.
don't forget to relearn RC and recalibrate temp.
also check in your Turbine Limits menu for any changes such as battery type and aux channel control as they've all been reset to default.
