120SX running temp
120SX running temp
Matt
My 120SX is running perfectly and does not seem to have a problem, but on the GSU I have an indication that the max temp is getting to over 900 degs, I have checked the temp probe insert depth and that is OK, the only anomaly is that at plug in the GSU is reading 18 deg not 21 degs as it used to, does this indicate I need to re calibrate my temp sensor?
Mike
Mike
My Feedback: (10)
RE: 120SX running temp
Hi Mike,
If that is the last max temperature, in all likelihood it occurred at start up, during the main ramp of kerosene. While a bit high it is no problem at this temperature as the exposure time is very small.
The value you are more interested in is the normal operating temp at max RPM. This is MaxRTemp.
I am guessing that is a lot less than 900. Let me know.
Regards,
Regards,
