Jetcat will not start
My Feedback: (26)
MB, CANADA
Hello all
Just puzzling, I banch test the 180, starts and runs great, I installed to my jet, it will not start,
I by pass the gas solenoid so gas direct to the engine, it fired up.
I thought the issue was the gas solenoid, so I changed to another solenoid, same thing happened, will not start, I by pass the 2rd solenoid, it fired up.
I thought it may be the ECU, switch to another ECU, change the setting on ECU, same thing, no go, I by pass the solenoid, it fired up and runs.
What could this be? Thanks
Al
Al
use the ECU to test the gas solenoid, with it being two valves and two ECUs doing the same thing i'd venture to say you've got the valve hooked up in the wrong spot or reverse polarity.
My Feedback: (26)
MB, CANADA
It worked, finnally, I did many changes with the gas line it's not funny, many call to Scott at jetcat, it's working.
What changed, the gas line hook up, and may be lose plug(s) at first or combinations of??????
Thanks Guys ................Life is good again -
Al
Al
