JR 900 Piezo Gyro
I have an almost new JR 900 Piezo Gyro in my Ergo 60 Sport with an 8103 on S-PCM with a 4735 on the tail. All equipment is in perfect condition no crashes. Upon setting up the tail rotor throw I have noticed that I am only getting about 75% servo throw. All ATV's are at 100% no mixing programs and have the aux plug into the aux2 on reciever.I have even tried two other JR Radios on the bench with the same result.The gyro is compensating good just at about 75% stick movement either direction servo stops moving . I know this is an older gyro but it has no time on it and any help would be greatly apreciated.
With a Piezo gyro, the travel you get is set by the gyro, and you will get full travel while flying, with the helicopter in operation, but you will likely not see full travel with the heli on the ground. This is normal.
