Spektrum Telemetry module and iPhone App.
I have the two ends of the satellite rx in the horizontal plane, while the antenna on the main receiver sits in the vertical plane... are you saying that I am losing 30db of signal reception.. cuz I show 0.0 holds and same goes for fades, zero point zero... Now it might be the same if I had both in the horizontal plane just one sitting 90 degrees to the other. Is that your recommendation?
I'm thinking that the TM1000 is transmitting but it is in a fore and aft position nose to tail and might not hit the DX8 very well when the antenna points directly at me and through the gas engine which is a pretty good chuck of metal. To overcome this, I plan on having the TM1K antenna move to a vertical plane using a coffee stir to exit out the belly, probably at a 45 degree.
Does this make sense?
KKKKFL
No to the first question:I am talking about Txer to Rxer communications (i.e. not a Rxer to Rxer interaction). In the case of Telemetry, the TM-1000 is a transmitter and the DX-8, for example, and the Sti are receivers.The orientation of two on board plane control surface Rxers as you describe them is not relevant, in this situation. RF wise they function independently from each other.With a plane that has two control surface Rxers you want one vertically polarized and one horizontally polarized. Both not being near each other and conductive material, which includes carbon fiber and metal. That would be my recommendation. But, ... I am sure you already have this figured out and properly implemented.
As to your plan to move the TM-1000's antenna; you are correct. The engine could be shielding the TM-1000's transmitted signal. Being that close to the TM-1000, that shield could have a significant signal reducing effect in front of the plane. But you would have to probably be out there a fair distance to see that effect. I have my TM-1000 antenna and the DX8's antennas both vertical for max effectiveness. If you really need max RF effectiveness that is another question. Both antennas being vertical tends to cancel out any actual "ground effect," and the way the plane is most often used, the TM-1000 is most often vertical. It may also be inverted a lot, but the antenna is still most-often vertical. With a vertically polarized TM-1000 antenna, if you flip the DX8's antenna to horizontal, for example, now you are cross-polarizing.<o></o>
I attached on a discussion paper on my take of this whole loss of RF comms and what you guys may be seeing with a occasional loss of GPS data. It has a bit more detail.
Based on his comments, my plan is to insert a skinny cocktail straw downward and through the belly. I will run the TM1000 antenna through this so that it exits at at least a 45 degree angle exposing the better part of the antenna, in a mostly vertical plane. This should reduce any masking of transmission going to the STi and the DX8... ( now here's a thought, I usually have the iPhone in my top brest pocket with the audio cable inside a light windbreaker - don't want to catch anything on the prop. So is the STi receiving data from the plane directly, or is it receiving data from the DX8? Seems the STi would have different drop outs since the DX8 is in my hands with the antenna in a quasi vertical (bent away from pointing at the aircraft).
I might be over thinking this problem...
Can't wait to see what happens with a new TM1000 antenna position WRT GPS drops.
KKKKFL
As I understand it, the STi would also be a Rxer, and it would be receiving the signal from the TM-1000. I do not have one of the little gizmos and Spektrum will not give us any schematics or even block diagrams, etc. But, the technical aspects of a DX8 repeating the signals to the STi alone make that theory unlikely. Also, why would I retransmit a signal that is already there?
But the DX8 and the STi being different receivers with possibly different sensitivity characteristics, different antennas, different antenna locations and different conditions at or near the two Rxers’ antennas, could result in the data showing up in one device and not the other or not showing up in both devices for different reasons. <o></o>
czorzella: Are you suggesting a separate post? That document is kind of detailed and wordy for the casual reader. I felt that the summary I posted sufficed for the casual reader and if someone was really interested, they could go to the attachment. But you could be right. ??[/b]
I wonder what would happen if I moved the iPhone from inside my coat (I usually drop it Dongle side down into a top shirt pocket) to a Belt holder where the STi is in a different orientation ( say length wise )
Another test would be to download the GPS data from the DX8 to Google maps and see if the DX8 data has drop outs in the same locations...
Oh boy we have some testing to do here.
KKKKFL
I sure would like someone to compare the data that is displayed on the iPhone to GPS data that is collected in the DX8 (using google maps)... This would tell me if data was lost ormasked before being senton the downlink.
KKKKFL
There is no Ack/Nak. The TM-1000 is broadcasting the data without error checking. If there were Acks (error checking) there would not be any lost telemetry data. Once the link between the Plane's "control surface Rxer" and the DX8 is established, the TM-1000 broadcast of data is enabled. As I understand it, that link essentially turns on theTM-1000. When it is on, it is broadcasting.<o></o>
As I understand it, the DX8 and the STi are independently receiving the TM-1000's broadcasted signal, like two different cars going down the road listening to the local music station. The cars do not acknowledge (Ack) the fact that the music is being received or not. You run your car out of the broadcaster's range and you do not get the music, etc. You run around in the fringe of that broadcaster's range and you only get part of the music. We were discussing what affects the range of the signal broadcasted by the TM-1000 and what could possibly cause that range to be intermittently shortened.
As far as testing, for any test to be a good test, eliminate as many variables as possible. I would start with the STI on a table next to the area you are using the DX8, with the STi’s antenna/STi oriented as it would be when you typically use it. In your pocket or near your body, the STi could be negatively impacted. When I use handheld radios I typically get them off my belt and out in front of my face, etc. When I am in the fringe areas, I get the radio up in the air and away from my body, especially when receiving. And, I use a heck of lot more power than what is used in the RC world. Once you eliminate as many variables as possible, then do the test. Record the result. Then change some of the variables, one at time, back toward how you would like to use/hold the device during normal flying and determine and record each change's impact.
You know, there is another effect I previously eluded to but did not fully explain. If the STi is too close to the DX8, the “control surface signals” sent by the DX8 could actually overload the front-end of the STi's receiver thus block the TM-1000’s broadcast. This could preclude the STi from receiving the data also. I left that one out of the discussion because the GPS data loss described seemed to fairly intermittent. But after thinking a bit more on the subject, depending on where the two devices are located and how the antennas are oriented, the physical distance between the two devices could cause “Rxer front-end overload.” This is another variable that could be "in-play" here.<o></o>
once link between the plane and the DX8 is established, then the TM1K links and so does the STi... I should be able to turn off the DX8 and still have the TM1000 sending data, albeit only the STi device listening... I think it was czorzilla that said that the STi data stops...
I'll go test this later this afternoon.
KKKKFL
That said,
KKKKFL
Perhaps it is important to mention that I never left the phone close to my body while flying; I always like to lay it down on top of a bench near by with the STI interface pointing towards the sky, but one day happened that I left the phone about 65' (20 meters) from me and it actually received the telemetry data.
Just ran that test...
Don't know who to credit,but it is true... you can have everything all locked and working with read outs from STi... the second you pull (shut off) the DX8, the STi drops link needles disappear... So there is SOME relationship between the STi and the DX8.. The TM1000 must have some working relationship with the airborn receiver that if link is lost the TM shut down the sending of data.
I'll go try with a second model just to make sure.
KKKKFL
This was interesting... I got everything up and running made sure the readings were coming, ie wiggled sticks and watched voltage reports.. all working as predicted..watch temps move. after a couple seconds I thought I would reverse the process, ie leave tx and STi running shut down receiver...
What happened was the needles disappeared on the STi HOWEVER, the link light on the STi stayed lit... It was like the STi was receiving data from the DX8 not the TM1000 and since the Receiver and TM1000 had no power there was no data to display, but the STi thought it had link....
Very interesting..
KKKKFL
Test 2 Turn off receiver but leave DX8 on and leave STi application running...
Very interesting..
KKKKFL
It does seem to indicate that the STi is linked to the DX8 and not to the TM1000. Let see if Mister Todd has any ideas given these findings.
This would also make the GPS drop out be in both the DX8 and the STi, since it looks like the STi is some how getting the data from the DX8 and not from the
TM1000. Any lost "real time" data going to the DX8 is gonna be missing in the STi as well.
KKKKFL
The DX8 talks, the rx listens. The TM1000 listens, too. Then it talks, when it knows the DX8 is silent. The DX8 listens, the STi listens for the TM1000.
If the TM1000 doesn't hear the DX8, it doesn't talk, but the DX8 and STi still listen for it.
The TM1000 has less range as both rx and tx than our standard receivers, by design. This way you can know that you're getting out of telemetry range (the tx will tell you, if you turn on alarms on the Flight Log). The STi antenna is confined and probably not nearly as sensitive as the DX8 (acting as rx), and when you put it up against your body, it's even less able to hear the TM1000.
Andy
Best Aircraft reception, place a satellite receiver with antennas in vertical plane, and main rx antennas in horizontal plane. For the TM1000 I am going to use a cocktail straw (available at any Mickey 'D's") poke it through the belly of the plane at a 45 degree angle and feed the TM1K antenna out. (in my RV-4 last night, I made this change and approximately the last 4 inches are now through the body. Question here, the last inch is exposed wire, is this the actual antenna, or is the antenna the entire wire as soon as it leaves the module case?). Now there are no "end point" dead zones.
As for the iPhone and STi, I sure would like to get an extension cable to plug into the bottom of the iPhone that was about 24 inches long. The iPhone could stay inside my coat top pocket, and the cable could run out along my collar and up to my Ball cap where I would plug it into the dongle and then velcro the STi dongle to the outside of the hat band. Velcro'ing the whole iPhone up there is just a little TOO geeky even for me...
Another option would be the use of wireless technology to get the audio to my ear from the iphone which could be placed on a stand nearby any of the flight line stations. This is an expensive way to go, and I do not know anyone that has broken the code as to which bluetooth devices would actually work. At a minimum, this approach is gonna cost a "C" note. I've also thought that clipping the iPhone holster to a jacket that has epulets so that the dongle faced out away from my body (kinda like the setup the police use where they clip the microphone up near a lapel) could be an option... Bottom line here is that it needs to by out and away from my body for best reception of the TM1000 signal.
Will take some of these ideas to the field tomorrow and let folks know how I make out.
KKKKFL
Using a BT audio is probably a bad idea. You're talking about putting a second 2.4g transmitter in close proximity to your telemetry receiver - perfect way to make sure you don't get good telemetry reception.
Andy
I'll try both this weekend
KKKKFL
Would there be concern were I to clip the iPhone to the handle of the DX8? It was a passing thought, but I dismissed it favoring the lapel clip approach instead. Another idea revolved around those armband things you see joggers use to listen to music while running.KKKKFL
Remember that the closer you get to the DX8 the more potential there is to overload the STi's Rxer. But if time domain multiplexing is being used, theoretically separation distance between the DX8 and STi should not be an issue precluding receipt of telemetry data. That being said; there are limits to everything. Testing would be a good idea though.
I attached a few more thoughts about telemetry data loss and lack of documentation, etc. that Andy's above statements initiated.
Concerning the iphone cable extender, maybe this one will do: www.radtech.us/products/procable-30pin-dock-extender
Andy,
As for placing the iphone near the antenna, I fully understand the consequences and that is why Ialways place my iphone away from the transmitter. My question:Is there a minimum recomended distance between the TX and STI to assure that one doesn't interfere with the other? Reason being is that if required distance is short enough, perhaps we could use one of those transmitter trays for FPV to hold the Iphone above the TX and antennas about 8 inches (20 cms.).
The other plane that I have used is my RussiaStik... same exact orientation, and curiously, same location of drop out, however, the drop out areas were smaller (gives rise to the"Mask" theory)
If you envision a race track in front of your position on a flight line, I always lost the GPS data when doing a landing approach where I would make a left turn on to a base leg (facing East, and looking to my left). The GPS tracking arrow would not reappear until almost touch down, so it was absent for a good bit of the final approach after dropping out on the turn to base. The electric plane seemed to regain GPS sooner. There were also drops off to my right but these were of much shorter duration... The difference here is that at that end of the race track I was always at a higher altitude... (80 feet on the landing approach for a start... other end of the runway I'm between 200 and 300 feet.)
I'll post a picture and explain where I see the drop if that helps making some evaluations.
KKKKFL
