JR 8103 FLAP PROGRAMMING
My Feedback: (29)
Can anyone help with step by step instructions for programming a JR 8103 for flaps using two servos PLEASE? I have spent all day trying to figure this out & it's driving me CRAZY.
RE: JR 8103 FLAP PROGRAMMING
ORIGINAL: roylab
Ch6 is your Flap channel. If you are using a servo for each Flap half, you can connect each servo to a separate channel, and use a Programmable Mix (PM 4 or 5) to mix them. You can also purchase a JR Matchbox, which allows you to connect both servos to one channel (Flap channel). Usually, the Left Flap servo has to be Reversed. You can do that in the Tx or in the Matchbox. I do not like Reversing Y Harnesses, so I do not recommend them since you have better choices.
My Feedback: (29)
Top Flite 60 SIZE P-47
Jr rx 649
one aileron servo
throttle servo
two flap servos on flap & aux 2 channels
one rudder servo
one elevator servo
Would like to be controlled by three way switch flaps up, half way & full.
Jr rx 649
one aileron servo
throttle servo
one rudder servo
one elevator servo
