8103 Fuse?
ON, CANADA
8103 Fuse?
Just got my 8103 a few days ago and finally got all my aircraft programmed into it and while I was setting up my Super Cub motor for better response I noticed that the 8103 XMTTR suddenly wouldn't come on!!??@#$&*)#$ Is there a fuse in it or something? I looked inside but could see nothing. It had been OK all day at the field. It wasn't run down and I didn't drop it! In fact it was just on the bench until I picked it up to check on the engine settings and bingo!! Gawd!! I don't want to have to send it down to Horizon the first week I get it! Any thoughts? The 652 had a fuse which blew a few times early in its career but has been rock solid the past two years. Please tell me there is a fuse in this too!
RE: 8103 Fuse?
There is a fuse, it is located just above the battery when you open the battery cover.
If it is the fuse, please give me some more information what causes the fuse to blow ? Danny if you can help aswell , I have the same radio.
Regards
Francois
Regards
Francois
RE: 8103 Fuse?
The 8103 has a fuse, it is located in between the battery pack and the module. You can remove the module and look down towards the battery and see the fuse. The fuse is a 3 amp, 250 volt, fast acting fuse, available at most radio shacks and similar stores. If changing the fuse does not correct it, you will need to send your system in.
