Binding the R921 Thru EMS Battery Backer
My Feedback: (15)
JR921 RX. Thought I had it made. First time to bind thru the Battery Backer, I need some info. I am set up with two 2150 mah Ni-Mih's, two switch harness', to the BB, then the single power from the BB to the receiver.
Insert bind plug to the main, or to main and backup, go with backup off, and/or with both powered up. Not binding with the BB in-line. Switch harness direct to the receiver, bind OK. I am on to the final bind after all servos in, etc.
Is it safe to just bind without the BB, then hook it in ? Advice appreciated, before I call EMS.
Crank
