TM1000 can it be plugged in the 9th channel with DX8
My Feedback: (34)
Ok guys. I'm building 3 TopFlite Gaint WarBirds
i think I really need a DX18 but I don't have that kind if $$ right now.
so my question. I'm useing a AR9000 in my P47 and I would like to use the TM1000 to monitor reciver voltage and maybe RPM
So even thow my DX8 only has 8 channels will it still work?
also I'm useing AR8000 in the othere 2 birds. All channels are full, so can it still work in the Data port?
thanks Mike
thanks Mike
RE: TM1000 can it be plugged in the 9th channel with DX8
ORIGINAL: mikes68charger
thanks Mike
thanks Mike
My Feedback: (34)
Thanks.
I just tested it out. You can put a Y harnes on that dat/batt port with the TM1000 and 1 of my 6.6 live reciver packs and it works great
I do not know why I thought it would not work if all 8 channels were full
How dose one test there signal strength/frame loss?
Thanks.
Thanks.
Can you measures RPM on 2 motors as per a twin motor set up B25?
Andy
