AR8360T and DX18
AR8360T and DX18
Hello all,
I recently purchased a AR8360T and I am not able to program it like the other AS3X receivers. The PC will only update the firmware, The phone app wont connect to it via BT, and my DX18 doesnt do the forward programming. I have a NX8 available to program it, but it does not have enough available channels to properly set it up and I believe once I switch over to the DX18, it will not function the same.
Anyone have any experience with this? The product info said it is "compatible" with my radio, but it would seem it is not. It doesnt make sense why they would remove the other programming options and make it only forward programmable.
It was a huge PIA to figure it out. The ar630 can only be forward programmed. Once the 630 was updated, I had to focus on updating my dx18. Then you had forward programming available to program the rx. The 630 will never work via the PC, only the transmitter.
My Feedback: (41)
Saw a thread over on RGGroups where a guy was having an issue getting his PC to talk to the Spektrum rx's. Seems as though there are two types of those, what are they USB3 cables? one of which only charges things but will not transmit data. Getting a new different cable fixed the guy's problem.
