JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
NX6 boot up issue
Old 10-28-2022, 05:06 AM
flatspin3
Default NX6 boot up issue
The first time turning NX6 on,the radio starts up with no start up sounds.
If connect receiver the frame losses start counting upwards every second. if i disconnect receiver and turn TX off,then back on,theTX boots up as normal,(with start up sounds),no frame losses.TX works fine.If i turn TX off for more that 10 min,i have to go thru the above procedure all over again.
Old 10-28-2022, 06:03 AM
AndyKunz
That is a known issue that we're working on. Only a handful of radios do it. You can return it under warranty for repair.
You don't have to turn on a receiver for this to work right. Just power on the radio once, and if it's silent, power cycle it again.
Then turn on your receiver.
Andy
Old 11-10-2022, 10:53 AM
flatspin3
Andy
Thank You! Sent mine in for repair,got it back in 6 days..GREAT SERVICE
Old 11-10-2022, 10:54 AM
AndyKunz
Be sure you register the new one radio. They replaced the main board in it, which changes the serial.
Andy
