IC3 to IC5 adapter
IC3 to IC5 adapter
I have 4 cell smart batteries with an ic3 plug and a 60 amp esc with a ic5 plug. I purchased an adaptor to fit between the battery and esc and while it works, it is too long. Is there an adaptor that just has the plugs without the wire in between?
Andy, I think what he's asking for is 3 infinitely short wires between the two connectors, not elimination of one of the wires.
PC, because of the mechanical differences and spacing requirements, no, there's isn't such a thing that I know of commercially available. You could make one by desoldering the wires from a commercial adapter, shortening them a bunch, and re-soldering. It won't be pretty. You would probably want to fill the gap in between with silicone to prevent shorts.
Or better yet, just replace the connector on the ESC.
Andy
Andy
BigBirdFlyer (04-11-2024)
