Jr xj14
In the ACRO programming configuration, the XG14 supports only one user-defined throttle curve. It is turned ON and OFF by the condition(s) set in the SW SEL submenu on page 2 of the THRO CURVE menu. When the curve is ON, the throttle output follows what is on the graph. When it is OFF, the throttle output linearly follows the stick position in the same manner as the graph indicated before it was modified. The graph doesn’t change when switching; but, there is a message in the upper left region of the menu screen that states if the curve is ON or OFF.
Allan
Allan
