JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR 10x...Bobcat...Brakes
Old 10-15-2003, 09:43 PM
Boating Bob
Default JR 10x...Bobcat...Brakes
I have a Bobcat and to apply brakes I am using down elevator. They come on only when the gear is down. Now I would like to use the right slider to also apply the brakes. It would be used like a emergency brake, when it is setting on the table. Can this be done. Iam using Aux 8 for the smooth stop.
Old 10-16-2003, 08:50 AM
dsnyder
dsnyder's Avatar
Default RE: JR 10x...Bobcat...Brakes
Yes, you can do that. Do you mean you are using channel 8? If so, all you will need to do is go to code 17 and make sure that it says ACT beside aux 3. Depending on the set up, travel adjusts, and things like that may need to be adjusted, depending on the set up needed. If you are using another channel, you can mix channel 8 to the channel you are using, press page twice, select MASTER ORIG on the left hand side of the screen, and press page again. Then set the percentages as needed. If you have any further questions on setting that up please let me know, or feel free to give one of our product support reps a call at 877-504-0233.
