8401s
AK
8401s
I was looking for specs on the 8401s I have 4 of this I can't seem to find any specs on them I was wanting to use then on the ailerons of a H-9 xtra 330S. Thanks. Mark,
AK
RE: 8401s
Hi Danny I was told they were the same as 8411sa will the non metal gears be alright or can I have 8411 gears put in at a reasonable price. Thanks, Mark,
RE: 8401s
If that is the case, the servo should not be used in over 1.20 size aircraft. You may be able to retrofit the 8411 gears, but I don't have any information to verify that.
RE: 8401s
Specs for the 8401 as follows....
Torque = 11 Kg/cm
Dims = 34.5 x 19 x 38 mm
Speed = 0.19 sec 60 degrees
Weight = 49 grams
Very similar to the NES8425. Hope that helps,
Torque = 11 Kg/cm
Weight = 49 grams
