Radio specs
Radio specs
Hi Danny,
I my arsenol of tools I have a IFR 1500 s( I'm a broadcast engineer during the day for a radio group here in Seattle) I use to maintain radios with. I'm familiar with Futaba radio settings and I keep track of them when they are either new or fresh from the factory. I do tune my own 6 meter stuff from time to time but I send in repairs. I'm into Combat robotics so I've made a habit of checking them after events. My problem is this the JR radios I have I got them used so I don't know what the normal deviation is on them. I have one in the 1.5 khz range and I've seen another at barely 1Khz of deviation. What are the factory settings for an f400 and a xf 421 on 75megs and what should the antenna legnth be on the recievers? I'd like to know when it's time to get them tuned.
Thanks Rob, KB7WNZ
Thanks Rob, KB7WNZ
RE: Radio specs
CQ KB7WNZ ,
Here in the UK the deviation is set to +/- 1.8KHz. I believe this is common throughout the JR range. The length of the antenna wire for the receivers is 1 metre ( 39.37 inches ).
Danny will ( I'm sure ) confirm this when he is next on line.
RE: Radio specs
That antenna length is correct for aircraft receivers, but receivers for surface that are 75 Mhz are 18-20 inches. I don't have information on the deviation that I can provide.
