BROKEN ANTENNA WIRE
TX
BROKEN ANTENNA WIRE
DANNY, MY BROTHER NEEDS TO KNOW WHAT GUAGE WIRE AND WHAT LENGTH I NEED TO REPLACE HIS RECIEVER ANTENNA SINCE HE FOUND IT BROKEN OFF,AND CAN I REPLACE THE MEMORY BATTERY IN HIS JR MODEL? COMPUTER TRANSMITTER WITH OUT LOSING ALL HIS SETTINGS,THE REVIEVER IS A JR MODEL NEC 910 XZ 72 MG AIRPLANE SET PCM THANKS FOR ANY HELP YOU CAN GIVE ME
RE: BROKEN ANTENNA WIRE
I would recommend using part number JRPA170 for the antenna, which is a direct replacement. The lithium memory battery is a soldered in component, and fairly difficult to change. Also the system will need to be reset afterwards. It is possible to change the lithium battery without losing the memory, but is farily difficult to change it that quickly, and if the battery is dead, chances are that the memory is gone already. It is much safer and easier to send the system in to have this done. Also if you would like, our service department will replace an antenna on the receiver at no charge, provided no other service or parts are required in addition to the antenna.
