10 x
My Feedback: (99)
TX
10 x
Hey Danny, im looking at buying a used 10x and its on channel 16. know is that still 72 MHZ or 53 Can i use the MOD. from my 8103 in the 10x. if this radio is 52 MHZ. what is the difference between 72 & 52.
Thanks dennis
Thanks dennis
RE: 10 x
I believe that channel 16 would be on 72 Mhz. You can use your module from the 8103 in the 10X, they use the same module. 52 Mhz is not a legal band in the US, for aircraft the legal bands are 72 Mhz, 50 Mhz, and 53 Mhz. This relates simply to the frequency that the system is on, and the components to use each band inside the module and the receiver are different.
