10x Dual Rate Settings
My Feedback: (10)
TX
I am using the dual elevator function on the 10x. When I program the dual rates the mid rates will not set the elevator halves straight across even when the 100% setting is straight. I have measured the all of the distances and they arrear to be equal. Thanks for your help.
This is an issue that I really am not sure of what is happening. The elevators change trim when flipping the dual rate switch? Are you using the dual elevator function in code 22? Do you have aux 3 inhibited in code 17? Or is this a travel issue where the elevators are not matching each other while moving the elevator stick?
My Feedback: (53)
Well i don't feel so bad now.....I was thinking maybe you had flight mode set-up with Flap (66) and not FLAP switch selected in the advance flap page......but it's not the case.
Hope product support can help you.
Daniel D.
Daniel D.
