JR tx & Hitec RX
JR tx & Hitec RX
You can only use those together if the hitec receiver says JR on it. If not, and it works with hitec, they are not compatible with each other. JR uses a positive shift in the signal, and Hitec uses a negative shift. This prevents them from working together.
