8103 on Delta mode setup?
I am in Delta wing configuration in my 8103. I need to reverse the direction on the ailerons and the elevators but everytime I use the reverse function on the elevator channel the elevator stick becomes the aileron channel and the aileron stick becomes the elevator channel on the TX. If I also reverse the aileron channel the aileron stick becomes the elevator channel and the elevator stick becomes the aileron channel on the TX as well. Can this be done?
Thanks! J. R.
Thanks! J. R.
RE: 8103 on Delta mode setup?
If you reverse one channel, chances are you will need to reverse the other as well in delta mode. To begin setting up a delta set up, get your ailerons moving the correct direction. If the ailerons are backwards, reverse both channels. Then if the elevators move the wrong direction, swap channels that the servos are plugged into the receiver, and it will reverse the elevator without affecting your ailerons.
