10X xmtr question
10X xmtr question
Danny,
Seems like I read/heard that channels 9 and 10 on a 10X had some
different characteristic than 1 thru 8. I'm thinking maybe they were
512 instead of 1024 or had a different refresh rate or something that
would prevent using them with another channel for ganging servos.
For example, if I wanted to run 2 servos on rudder but rather than use
a Matchbox I wanted to use 2 slaved channels, I would not want to use
channels 6 & 10 for the task. Did I dream that up ? Thanks for your help.
RE: 10X xmtr question
Channels 9 and 10 on the 10 series systems are updated half as often as channels 1 through 8. I recommend channels 9 and 10 being used only for on-off type functions such as: gear, flaps, brakes, etc. Things that do not need high accuracy and as smooth movement.
