Flaps not going down together
CA
I have a JR xp6102 PCM radio and I use one channel (537 servos with a 'Y' connector) for the ailerons and they work fine each goes in different directions. I tried the same with AUX1 for the flaps after setting everything as Hanger 9 says for the P51 1.50 mustang I can not get the flaps to lower together they act just as though they are ailerons is there a programming of the radio I need to do? If I connect each flap separately the flap works fine.
Any suggestions
Any suggestions
NC
RE: Flaps not going down together
You are using a regular "Y" connector for the ailerons: That is correct.
For Flaps you need to either reverse one of the servos internally or an easier way would be to use a special "Y" which reverses one of the two servos.
Personally I didn't want to open up a servo and mess with it, so I opted for buying the "Y" connector with a reversed output for one of the servos. Worked great for me.
The above was a recommendation in the manual for my Hangar9 Ultra Stick 60.
I don't recall the price, between $20-$30, but I like to say may be $30. Mine had really long wires.
Good luck.
Gryphon
Good luck.
Gryphon
