JR XP 783 - 120 Deg CCPM?
RE: JR XP 783 - 120 Deg CCPM?
It has many of the same features as the 8103 and 378. Is there anything specific that you are needing? The 783 will do 120 CCPM after activation. To find if your system has this activated, press and hold the up an dn keys together and turn the system on. Then either select a heli model, or go to model type on a clear model and select heli. Then scroll through with the up or down key and see if there is a menu option that says mix SWAS. If this is there, the system has CCPM activated. If not, you can send the system in for activation, this is a free service. The 783 is capable of PPM (FM), ZPCM, and SPCM, it will work with virtually any JR receiver on the same band.
