xf421 flaperon
TN
xf421 flaperon
trying to use 2 aileron servo one in gear channel cannot get the one in gear channel travel adj. aileron travel adj affect only right wing gear travel adj affect centering both aileron will work and in correct direction but the left one has too much travel thanks for any help
RE: xf421 flaperon
The procedure I recommend is to set up the servo plugged into channel 5 mechanically to get the throw desired, then set up the servo plugged into channel 2 mechanically the same, then adjust the aileron channel travel adjust to make them match if necessary. Adjusting channel 5's travel adjust will adjust the flap travel of both channels. Also be sure to zero the flap travel adjust in one of the 2 switch positions so that the servos will be centered properly.
