DELAY ON AUX CHANNELS
DANNY,
I DO NOT KNOW IF SOME ONE HAS ASKED THIS BEFORE BUT IS THERE A WAY TO AVOID THE DELAY THAT I GET WITH THE ELEVATOR AND AUX 2 OR 3 FROM MY JR PCM 10S?. I AM SURE I ALSO HAVE IT ON THE AILERON AND AUX 2,BUT IS NOT AS NOTICIBLE AS WITH THE ELEVATORS ON TWO SERVOS.
LAZETA
LAZETA
RE: DELAY ON AUX CHANNELS
There is not a delay on the channels themselves. To set up mixes for dual elevators etc, make sure your percentages are both +100%, and that you have inhibited the switch, slider, etc that controls the slaved channel either by going into code 17 for those channels available there, or by using a program mix where you mix the channel to itself and set the rates to -100%. Then verify that the travel adjust values for both channels are the same, or very close to each other. From there it is a matter of matching servos that have the same throw and centering.
