JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
XF-421-EX Flaperon
Old 09-06-2004, 03:31 AM
bluemagic98
bluemagic98's Avatar
Default XF-421-EX Flaperon
I dont know if theis is righr but i added flaperons to my plane and when i did i lost 1/2 the up travel to get it back i had to max out the alieron sub trim in one direction and the gear servo being the opsing alieron in the other direction and move the servo horns on the servos now i have ful up and down when not ussing flarperons. is this the way its ment to work? also can you reduce the amount of flaps? thank you for your time.
Old 09-07-2004, 01:51 PM
dsnyder
dsnyder's Avatar
Default RE: XF-421-EX Flaperon
Go to your travel adjust function, flip the switch in the direction you want the flaps off, and zero the gear channel travel. Then center the servos in that position. Then you can reduce the flap throw by adjusting the travel adjust on the gear channel.
Old 09-07-2004, 03:32 PM
bluemagic98
that worked well thank you i was confussed seeing the sub trim was maxed out in each channel in opposit directions to get full taravel i was thinking the travel adjustments worked independently as well but it is giving me 1/2 flaps and full flaps so I thank you for your time it worked very well
Old 09-08-2004, 02:22 PM
dsnyder
dsnyder's Avatar
Great to hear! Let us know if you have any further questions.
