Can the 9303 upload plane info from 8103?
NC
Hi Danny,
I was wondering if you could help answer my question.
Do you know if the new JR 9303 can upload plane info from an 8103 or XP652?
***That is assuming that we are not changing the standard switch assignments.***
Thank you,
Gryphon
Thank you,
Gryphon
RE: Can the 9303 upload plane info from 8103?
I think you will find that the answer to that is no.
You would need a 3rd party programme to deal with that. As is common with the other sets in the JR range ( that support data transfer ) you can onlt transfer directly between identical sets.
The 9X ( which the 9303 is based on) outputs the data stream in a new way and would be totally unreadable by any other set, ditto for incoming data.
NC
Thank you Mac_Man_UK,
Can the DataSafe 2 PC Interface Set (Part Number: JRPA301, $99.99) and a computer be used to help accomplish this?
Thanks again,
Gryphon
Thanks again,
Gryphon
Unfortunately, I cannot answer that. I dont have access to Datasafe as I am based in the UK.
But I will hazard a guess and say that it wont in its current state because the data stream coming from the system being the reverse of the previous JR systems.
Sorry.........
Sorry.........
