maintenance
RE: maintenance
We recommend having systems checked over on a yearly basis if you fly regularly. If you have been using them for 5 years, I would recommend sending them in for a check up as soon as it is convienient to do so.
There are no upgrades available for the datasafe systems, except for the original datasafe (25 pin connector version) to make it work with the 8103 digital trim system.
