mixing elevator servos
Danny,
How do I mix the elevator servos on a 9x transmitter so both servos will travel in the same direction and the trim lever will trim both sides equally.
RE: mixing elevator servos
I'm not sure on the 9X, I don't have one to look at. On the US 9303 system you can activate dual elevator in the wing type, after inhibiting a channel in device select.
