Voltage in 6102.......How can you tell ????
CA
How do you check the battery voltage on this transmitter? On most every other transmitter I have seen, the start-up screen shows you the current voltage. I downloaded the owners manual for the 6102, and unless I'm missing something, no where does it show what the voltage is.
I was seriously considering purchasing this transmitter, but what I stated above is true, there is no way that I am going to possibly lose a plane because I couldn't tell how much voltage was in the xmitter batts. Yeah, it has an alarm to warn you of low voltage, but that's like driving a car without a gas gauge.............just an alarm to tell you that in 3 blocks, you're gonna run out of gas.
Am I missing something here......???
CA
RE: Voltage in 6102.......How can you tell ????
ORIGINAL: twistr
I own this TX and the screen tells you the voltage at all times. You won't be dissapointed with this TX!
This is good news...........Thank you.........for I am seriously considering this transmitter. Trying to decide between the 6102, and the the 7c............
The 6102 displays the voltage in the upper right hand corner of the screen, and it also has a bar graph indicating charge status on the top of the screen, with a mark indicating a fly/do not fly point (or a do not fly below point).
