9x device select prob
On my 9x i am trying to setup a four servo glider wing, anyhow to use some of the mixing i have to deactivate one of the channels first and then use dual flaps etc, my problem is that when the radio is in Glider mode Device select does not show up in the system menu, if i am in aircraft mode device Select is available. Any ideas!!!!!!
