8103,dual elev.servo mix
RE: 8103,dual elev.servo mix
Here is a link to a programming guide that should help in the set up of that:
http://www.horizonhobby.com/ProdInfo...amming-air.pdf
Hi Danny,
I have a JR 8103 and just got a Chip Hyde Double Vision. How can I program the upper wing for flaperons while leaving the lower wing as only ailerons? Thanks
Terry
Terry
NJ
ORIGINAL: dsnyder
Frank
No problem Frank, let us know if you have any further questions.
Terry, this is easiest accomplished by using glider mode. To do so, set the model type to glider, activate dual flaps in the wing type menu. Plug the bottom right aileron in channel 2, the bottom left in channel 5, the top right in channel 6, and the top left in channel 7. The use a program mix (mix 5 or 6 for this mix) where you will mix aileron to flaperon, assign it to a switch if you want to be able to control the top wing as flaps only, and set the percentages to +100% in both directions aileron in one switch position. You can then control the top wing as flaps via the flap switch by turning the flap channel to FLAP.SW+P6 in the FLAP IN. menu option in the system mode, or you can use elevator to flap mixing, or flap to flap mixing to set it up as desired.
NJ
Hey Danny,
This is something different then before... My dad has a Zero fighter,can he put the flaps on the flap/land sw. ordoes it need to stay on the flap knob? It would be easier to use the flaps this way..
Frank
Frank
To use the switch, you can access the landing menu and set up the flaps in the LAND switch position. To set another position would require a program mix, assigning it to the ELE>F switch position, and possibly require entering an offset. This can also be set up in glider mode (in glider mode you can also set up dual ailerons and dual flaps easily) and select FLP.SW+P6 in the FLAP IN. function in the system mode.
OH
Danny,
I have a DV that I would like to put flaps on the top wing also, I'm using two channels for my elevator, so which JR receiver will work for this type of setup (I'm using Ham freq.)
