8103 replacement batterys
Danny
I have looked but can't find the TX and RX replacement batteries for my XP8103DT. The receiver pack is a 4N600 and the transmitter pack is a JR-2S. Both are 600mAh batteries. One at 4.8v the other at 9.6v What is the part number so I can order replacement batteries? I have had them now for some time and would like to replace them both and order an extra receiver battery pack.
Mike
Mike
RE: 8103 replacement batterys
I guess I should have also asked if there are larger mAh replacement batteries available that would be a direct replacement for both..
Mike
Mike
I got a 1400ma NiMH battery pack for the 8103 Tx from AlleRC and the connector from MPI Maxx. Receiver batteries are a dime a dozen so to speak, you don't need a JR pack just one with the JR connector. Most LHS's carry a variety of battery packs or there is the internet with many places to find packs of all different sizes.
For the transmitter pack, you'll need to look at the connector on the battery to find if it is a white connector or a black connector. The batteries we have for each connector are:
JRPB955 *TX NICD 700MA(WHITE CONN):4-8
JRPB9081 *EXTRA TX NICD 800MA(WHITE CON)
JRPB954 TX 600MA NICAD,BLACK CONN):4-8CH
JRPB9080 EXTRATX NICAD800MAH,BLACK CONN:4-8
For the receiver pack, JR offers these batteries, choose an adequate size pack for the model you wish to use it in:
JRPB3040 STD RX PACK 270MAH 4.8V FLAT
JRPB3041 STD RX PACK 270MAH 4.8V SQUARE
JRPB3050 STD RX PACK 270MAH 6V FLAT
JRPB3140 STD RX PACK 700MAH 4.8V FLAT
JRPB3141 STD RX PACK 700MAH 4.8V SQUARE
JRPB3150 STD RX PACK 700MAH 6V FLAT
JRPB3240 STD RX PACK 1500MAH 4.8V FLAT
JRPB3241 STD RX PACK 1500MAH 4.8V SQUARE
JRPB3250 STD RX PACK 1500MAH 6V FLAT
JRPB4040 EXTRA RX PACK 600MAH 4.8V FLAT
JRPB4041 EXTRA RX PACK 600MAH 4.8V SQUARE
JRPB4050 EXTRA RX PACK 600MAH 6V FLAT
JRPB4140 EXTRA RX PACK 800MAH 4.8V FLAT
JRPB4141 EXTRA RX PACK 800MAH 4.8V SQUARE
JRPB4150 EXTRA RX PACK 800MAH 6V FLAT
JRPB4240 EXTRA RX PACK 1100MAH 4.8V FLAT
JRPB4241 EXTRA RX PACK 1100MAH 4.8V SQUARE
JRPB4250 EXTRA RX PACK 1100MAH 6V FLAT
JRPB4340 EXTRA RX PACK 1400MAH 4.8V FLAT
JRPB4341 EXTRA RX PACK 1400MAH 4.8V SQUARE
JRPB4350 EXTRA RX PACK 1400MAH 6V FLAT
JRPB4440 EXTRA RX PACK 1800MAH 4.8V FLAT
JRPB4441 EXTRA RX PACK 1800MAH 4.8V SQUARE
JRPB4450 EXTRA RX PACK 1800MAH 6V FLAT
JRPB4460 EXTRA RX PACK 2400MAH 4.8V FLAT
JRPB4461 EXTRA RX PACK 2400MAH 4.8V SQUA
JRPB4470 EXTRA RX PACK 2400MAH 6.0V FLAT
JRPB4540 EXTRA RX PACK 3000MAH 4.8V FLAT
JRPB4541 EXTRA RX PACK 3000MAH 4.8V SQUARE
JRPB4550 EXTRA RX PACK 3000MAH 6V FLAT
