JR servos not working with Novak Synth Receiver
Whats going on people. I am new to this forum. I just got my LST. I sold the ready for the truck and the receiver becauase I have the airtronics M8 with Synthesized receivers. Ok I brought the truck home and i tried to install the novak receiver into my truck. I connected the servos and IT DID NOT WORK. I thought i might have installed the device backwards so i changed the pin around ( did a 180 ).
When i connected all three servo connectors when i moved the transmitter, the servos didnt move really it kinda moved like the batter was dead then stopped worked completely. I know the receiver works because i moved it back to my ofna buggy which uses hitec servos anI tried it my RS4 with Airtronics servos.
I am going to all over this. [:@]
Anyone out there know if this setup[]
JR Servos ( z270 and z590m ) with M8 Sythensized receiver and transmitter.
RE: JR servos not working with Novak Synth Receiver
Check to be sure you are getting power to the receiver, and that the servos are plugged in correctly. You can also verify if the servos are working with the system the truck came with.
ORIGINAL: dsnyder
I called the horizon today and they told me to send the receivers back to them. I think that I am going check with LHS before i send it in. I cant believe that this is going down like this. I waited for a long time to get this truck and now its not working. This burns
We do not guarantee that our equipment will work with other brands of equipment. It sounds to me like either there isn't sufficient power being delieverd to the receiver, or not plugged in correctly. There would be no purpose to send us a novak receiver, we do not work on them. I would recommend you contact Novak for further assistance with that. You can send the servos in to us for a check up though.
