Need helt with flapperon on my JR PCM 9X
Hi
I have set up a 5 channel receiver on a glider.
On my JR PCM 9X I have set up the Glider program, and used FLP->Ail Mix to set up "spoiler" and "Flaps" using the ailerons.
It seems that I can assign the "flight Mode" switch to this, but I would like to assign the "flap" switch to do this. How do I go forth doing this ?
Any feedback Appriciated.
On forehand thanks.
Erik
On forehand thanks.
Erik
RE: Need helt with flapperon on my JR PCM 9X
The only way I can see that this would be possible is if the flight mode switch is the flap switch, you can then set this on that switch. Otherwise I don't see that it is possible.
