PCM 9X Programmable Mixing II
Danny or Mac Man please help,
When I try to allocate/select a switch for a progammable mix with my PCM 9X, I can only view four switches AIL DR, EL DR, RUD DR and MIX. I can not see the switches of the AUX channels. In both the Horizon and McGregor manuals this is possible. I don't think that there is only one switch available for mixing if you consider that the DR switches will be used by default. If this is the case this Tx is useless for advanced flying.
I also can not change the position of the switches. For example when I change the Gear to RUD DR, the change does not take place. Also I can not disable the flap trim switch.
I have one of the very first PCM 9Xs came in the market about a year ago. It was brought directly from Japan. Do you think that it needs a software update or something?
Looking forward to your replies,
Regards Nick
Regards Nick
