JR X-378 Flaps/Dive brakes
NY
I have a SkyShark Dauntless and I was going over the instructions and plans. I like to have both the flaps and dive flaps functional. I have a JR X-378 7 channel radio and it has a 3 position lever. Elev – Off – Land Flap Mix. I've gone through the manual looking to see how I can set it up. Is anyone familiar with the JR X-378 that can explain how to set it up to use flaps on the down position and flaps/dive flaps in the up position? Or is there another way of programming the radio to be able to have both sets of flaps work.
Thanks in advance for any help.
RE: JR X-378 Flaps/Dive brakes
I would recommend using glider mode to set this up. It will be much simpler to use glider mode. Much of the programming used for the ultra stick could be used on this type of model, here is a guide that may help set this up.
http://www.horizonhobby.com/ProdInfo...ultrastick.pdf
