JR 241 OUTPUT ARMS
My Feedback: (62)
JR 241 OUTPUT ARMS
Danny, I'm looking for servo arms that are longer than supplied with the servo. The servos are side mounted and slots cannot be cut into the side of the airplane. This means one or more arms may have to be removed. Also, the plastic shaft hole walls need to be thin and not protude outside the servo sides. Can you help?
RE: JR 241 OUTPUT ARMS
Any standard JR servo arm will work on the 241's. Some of the options I see listed are:
JRPA211 OFFSET ARMS W/SCREWS
JRPA212 LARGE ARMS W/SCREWS
JRPA216 HD LG SERVO WHEELS W/SCREWS
JRPA217 HD SM SERVO WHEELS W/SCREWS
DUB671 SUPER STRENGTH SERVO ARM:JR
DUB674 STANDARD SERVO ARMS:JR
My Feedback: (62)
Danny, I have most of those but if you will look at the sidewalls of the arm especailly the 241's you will find that the mini's have very thin walls which allows you to cut an arm off and have the servo lay flat without rocking as it would with a normal arm.
