Differential Airlerons with a JR6102
My Feedback: (32)
I noticed in the JR 6102's manual that it states to look at the section for Differential Airleron Mixing and learn how to setup differential ailerons, but no where that I can find in the manual is that section [:@].
Can someone let me in on how to do this []. I want to have nore up then down on both sides to better tighten up rolls (more axial)
RE: Differential Airlerons with a JR6102
Yes, that is an omission in the manual. To access differential, activate flaperons in the wing type, then access the differential function in the main menu, and set as desired.
My Feedback: (32)
Thanks Danny,
I am pretty sure I have an idea of where the differentail function is but can you please give me a little better idea of exactly where it is.
I beleive you are speaking of the menu when I already have the radio on and hit the down and select buttons, or are you speaking of having those buttons pressed, then power on the radio.
BTW..I have the wing set for flaperon...
This is the function menu, the one you turn the system on, then enter. It also has the functions sub trim, travel adjust, dual rates, etc. Differential will show up between the flap system function and program mix number 1.
