8103 dual servo 3d setup issue
NY
Danny, I read the setup guide and everything set up as described. I have the travel limits set to 150% on elev and spoi for max throws. When I setup mix 3 to cancel out the aux control It only lets me go to -125%. This does not cancel it out unless I set the travel limits to 125% also. Is there a way to set this up so I can use 150% travel limit? I am sure I'm missing something easy but I don't know what it is.
RE: 8103 dual servo 3d setup issue
You could try another program mix, spoi to spoi again, and set it to -25% or so and see if that will take away the rest of the function of the pot. That would be the only other option. If that doesn't work, you'll need to set your travel adjust to 125%.
