where is #1 position
NV
can some one tell me where the number 1 position is on the RS300...Is it on the out side edge or in side..i'm trying to hook up my esc and want to make sure it's wired correctly.. I'm using a Msonik 3 truck esc...thanks for your help
RE: where is #1 position
The ESC will plug into channel 2, the wire code from inside out should be signal (generally white or orange), positive (red), and negative (black or brown). The negative wire will be closest to the side of the case.
