9303 PCM Fail Safe
My Feedback: (8)
FL
9303 PCM Fail Safe
Danny,
I am new to PCM radios, first one is this 9303. When programming the fail safe you have a choice between hold, which I assume holds whatever position the surfaces are in at the time of interference, and another option. How exactly do you program the position you want the surfaces to go to in the event of interference, other than hold???
thanks,
Greg
thanks,
Greg
RE: 9303 PCM Fail Safe
Go to the fail safe function, move the shaded box to F.S. (up position), move that channel to the position desired, and press the CLR button which will say MEMO beside it.
