9303 trim levels and gyro sens?
MD
Is there a way to link the right trim lever to change my gyro sens? Im using aux2 for it and right now I have switch aux 2 setup to change rate/HH modes and Im using the aux 2 channel travel adjustments to change it. But it wouls be nice it I could link a trim lever to tweak it while flying
RE: 9303 trim levels and gyro sens?
If you are using the gyro sens function there is no way to set that up. If you are using the gyro sens function, no functions can be programmed to aux 2, so it would not be possible.
MD
i have gyro sens turned off. right now i have the 3 position switch aux 2 setup to turn it form rate mode to HH. and have the sens lead plugged into aux 2 on the reciever. I set my sens by adjusting the travel of aux 2.
In that case, if you are not using aux 3 channel for anything, you could use an aux 3 to aux 2 mix and use the slider on the right hand side for this purpose. Just set up the mix, and enter the rates desired.
