537with broken tooth
hi, i had a 537 servo strip a couple of teeth on the main gear( the one with the stop on it) at exactly mid point, so i cut off the stop on it and ca'd it 180 to the other side(to move the stripped teeth 180 out) and am now using it for my throttle on my saito 100.i stripped it using it as a ele servo on a ucd 60. it is a little noiser than the others now but i can see no mechanical problems, is this ok?
