8103 battery low voltage?????
VA
Danny, does the 8103 have an automatic shut down if the battery voltage drops too low, and if so what is it set to? I thought it did, but I cannot find it in the manual.
The idiot behind the keyboard managed to turn the radio on while putting it in the car and it stayed on all night. I'm just curious how low the battery may have gotten.
RE: 8103 battery low voltage?????
Fraid not..... all that will happen is that the radio will start screaming at you ( at 9.0V ) and then keep declining........
[8D]
VA
Well I may have ruined the battery then since it was likely on for 21 hours after 40 minutes of flight. I suspect it has been over discharged.
