8611 Conversion
My Feedback: (25)
AR
8611 Conversion
If I send servos in to be converted, do they get the new case only or do they get both case and the new motor?
Also... I have a couple new cases here, but they do not have bearings in the top half. How do I get the bearing out of the old cases without damaging them. Also, what is best to use for lube in the new cases (pins, etc...) I can't find anyone that sells servo grease any more.
Thanks.
Thanks.
RE: 8611 Conversion
If you send in 8611's for the case top upgrade, only the case top will be changed. The servo will not be converted to the 8611A with the new motor. I assume you mean the bushing for the pin in the case top? If so, it is a press fit, and may be difficult to remove. It will take some prying with some type of a small tool that will fit inside the bushing to pry it out. The bushing comes installed in the 8611 cases.
My Feedback: (25)
AR
RE: 8611 Conversion
I do not mean the bushing. I mean the top bearing for the splined output shaft. Is it easy to remove and install in the new case top?
Also... what for lube?
Thanks.
Thanks.
My Feedback: (118)
RE: 8611 Conversion
I would like to send my 4 8611s in for the conversion, also I would like to send my 8411s in for a check of the gear train and I need one case top replaced on one of the 8411s(broken mounting lug) how would I go about doing this, thanks Gerald
RE: 8611 Conversion
Send them in for service with a note explaining what needs to be done.
http://www.horizonhobby.com/media/pd...rchecklist.pdf
My Feedback: (54)
RE: 8611 Conversion
Danny - Is this conversion a recall? I am happy so far with the performance of my original 8611's and there is a great deal of effort and down time involved in sending them in. I have 2 of them on rudder and 4 on airlerons, 2 elevator on my 33% plane. I don't feel they are being pushed anywhere near their limit so will it be OK to continue using them without the conversion?
RE: 8611 Conversion
No, there isn't any recall on the 8611. It is just an upgrade to the case which allows it to better withstand higher shock loads like flutter and bumping of a control surface etc. In normal operation it will not change anything of the performance of the servo. You can use the servos without any extra risk or anything like that. I've had the case top crack on a model in the past, and the only thing you can notice is an increase in what appears to be gear slop, but the servo will still function normally. If you notice an increase in gear slop, it may be the servo case.
