JR 8103 Mixing
RE: JR 8103 Mixing
You can activate flaperon mixing, then use mix 5 and mix 6 to mix aileron to the aux channel of your choice with the rates set at 100%. Then inhibit the flap pot in the flap pot function, and set up 2 program mixes, mixes 3 and 4, where you will mix each of the 2 other aux channels to themselves, say aux 2 to aux 2, and set the rates to -100% in each direction. To set this up, you will only have 2 mixes remaining. Your other option would be to use 2 Y harnesses or 2 matchboxes along with the flaperon function, or set up all 4 servos through the matchbox, only you will not have the ability to use the ailerons as flaps or spoilers.
